Dimension for form doesn't show up.
I've seen this before but I'd like to know what is wrong and if there is a way to resolve this. And I searched the faq's and did not find an answer. My problem is that I installed a louver on a sheet metal door and then attempted to pattern the form. However in order to pattern the form I have to be able to select the dimensions. This is where the problem occurs. The dimensions do not show up. In fact even if I try to edit the form the dimensions don't show up. The only way I can get to the constraining dimentions is to show up is to do "Edit Definition". But I can't get the dims to show up so they are selectable when trying to edit them or when I need to select them to pattern the feature. I hope I've described this well enough to understand, but I'd ask, "has anyone else seen this?" and does anyone know why the dims won't show up?
RE: Dimension for form doesn't show up.
You can pattern by direction, instead of dimension, and you can use the dimension name (eg d0) to ensure that it patterns correctly.
