Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I love this site! It's so nice to know that there are so many people out there who are willing to share their knowledge..."
Geography
jonnycowboy (Mechanical)
23 Apr 12 9:14
Hi all,
I'm looking for a threadable pressure port, the smallest possible.  The pressure sensing and "working" lines have very small diameters (~20 thou ").
I need the sense line to be 90 degrees to the "working" line   I'm wondering if I have to use something fairly large or is there something available in this size range?
To clarify what I mean by "threadable", the ideal would be to have a threaded hole on the part in which the pressure line is drilled, and then screw in an insert to a more standard sense line size (80 thou " or ~2mm).
hacksaw (Mechanical)
24 Apr 12 16:51
plenty of methods to make your pressure tap, but more importantly you need to define what pressure you are actually trying to measure and at what mach no.
25 Apr 12 11:17
The pressure will be low (total and dynamic pressure measurements), my sensors are capable of 0-30psia  max.
I have found some threadable ports but they have M5 threads, that's too big. I was hoping for M3 (or similar imperial size) with 0.025" holes.
26 Apr 12 8:05
I found something:
http://www.beswick.com/products/product_details.php?pid=8
The flow-through size is a bit bigger than I hoped but I think it'll be OK.
26 Apr 12 11:11
that is not going to give you a valid pressure measurement unless your velocity is really low
is this for process piping
27 Apr 12 10:38
No it's for AOA probe use.
NACA report 1364 shows that small pressure ports are the most effective (0.020"-0.030" generally).  That's tiny, I know and unfortunately I won't be able to do it on my lathe, I'll need to use EDM drilling.
Unless you have experience otherwise, that using a small drill hole (1/16) would be acceptable?
IRstuff (Aerospace)
27 Apr 12 18:03
???  It's not my field, but I don't get that conclusion from that report.  It seems to be talking about having smaller orifices on a relatively larger tube.  It mentions 25mil and 32mil as being better than 52mil.  It also seems to stress the importance of having good profiling of the orifice:
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19930092348_1993092348.pdf
TTFN
30 Apr 12 14:01
there are smaller drills for manual drilling but that is all it would be and not a proper pressure port
you might consider a tube insert rather than a drilled port
how do you plan to test your custom AOA/pitot measurement?
30 Apr 12 14:51
I never thought of using a tube insert, that's a really good idea.  I guess I would bond it in? Or simply heat the big tube, chill the small one and insert it with a small interference fit?
Testing: intially calibrated in freestream (ie: outside) and then in a wind tunnel.
30 Apr 12 16:22
sounds like you are just making a pitot rather than angle of attack probe, regardless, there are a number of methods to secure the tube depending on the temp range
for both measurements the edge effects of the port are important
2 May 12 10:19
I am doing both pitot and AOA in a single probe.  AOA will be measuring the pressure difference between the bottom and the top probes (known as a smart probe).
That's good information for the edge effects, I was just going to bevel the edges of the holes but I'll take a look at detailed information on this point.
For the temp range, the probe will be unheated (limited to "sunny day" operation). so probably -20C to +55C (DO-160 CAT A2 for temp)
IRstuff (Aerospace)
2 May 12 11:42
I still don't get why you need a separate tube.  The paper seems to suggest that a straight, unbeveled hole is all that's needed.
TTFN
2 May 12 15:47
just buy an AOA probe, you are getting into a can of worms with a beveled port , but given that you were going to use a hose bib initially, maybe thats all you really need
sunny days -20C to 55C, famous last words, that's not enough, just get a heated probe that has been design and tested. ice crystals are very small but they can really make a mess
pmrobert (Automotive)
12 May 12 9:00
Any chance a modified carburetor jet might be of value? Small hole, threaded insert, etc...
25 May 12 11:53
pmrobert, another great idea, thanks!!
Close Box
Join Eng-Tips® Today!
Join Us             Close
