How to recover used nitrogen
Hi
need some opinion on how to recover back used nitrogen. Can i rework the nitrogen gas we are venting out to atmosphere by re routing the nitrogen pipeline to atmosphere back for process usage.
N.B. The nitrogen is used in the fluidise dryer system. Based on pressure control in the dryer, excess nitrogen is vented out to atmospere.
RE: How to recover used nitrogen
You will need a condenser (finned tubes works well) to remove whatver you got from drying, a simple filter, and a gas compressor (probably root type if you work below 0.8 barg).
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
