Video RAM not enough?
Does any one know what the minimum video RAM SW2001 Plus would need to run? We run SW on a Duron 1200 256 Ram with 16Mb on board graphics. I realise it is struggling with this. Would this be the cause of SW crashing when I attempt to activate the Surfaces toolbar (just moving the bar crashes SW)We are running SW with Win 2000 Pro on two computers. There is no problems on the other one which uses a Athon 2.1 with 512Mb Ram and a 128Mb Graphics card (smooth .
I'm trying to persuade my boss to upgrade the slower PC but it's only two months old and he's not eager so any response I can wave under his nose would be appreciated.
RE: Video RAM not enough?
I use the GF2 ultra with 64MB, Win2000 PRO, 640MB Ram and I don't have any trouble.
Use this site to help detemine and card that is right for you.
http://www.solidworks.com/swdocs/support/html/videoissues/videotest.cfm
You should run at least 32 if not 64MB. 16 is way to low to run SW. Everything else you listed seems look fine.
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help*
Half of your problem is that you are using a Duron processor.  When you think of Duron, think of Celeron.  Durons weren't made with high end graphics and mathematics in mind, they were made to compete with the lower tier Celerons.  Case in point, the other computer has an Athlon processor, and you're not having the same problems.
SW should be used with at least a 32mb graphics card (though it does basic stuff with 16mb), but consider 64mb if you are in a professional environment.
When they say "system requirements" they are talking about the minimum requirements to get the program to work.  If YOU want to work, you'll have to go beyond the "minimum".
"The attempt and not the deed confounds us."
