Insulation in Reinforced CMU Cores
Is it allowed to leave cmu insulation in cores having vertical reinforcing bars?
It would seem to me that it would cause a bond breaker to the cmu shells.
Unfortunately there often surfaces a conflict with the energy conservation part of the Building Code when we try to use a single wythe exterior masonry wall.
RE: Insulation in Reinforced CMU Cores
You can, of course, alternate between adjacent vertical cells (rebar in one, insulation in the next three, rebar in the next, etc.).
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
The Architects scratch their heads trying to meet the requirements of energy section of the code when insulation gets voided.
They (the foam inserts) are not frequently used because of the thermal effectiveness and superior performance of rigid XPS to isolate the masonry mass on the the side of the insulation where it will be most effective for long term comfort and economy.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
You make no sense. Sorry.
Are you saying that this special foam is as strong as the mortar infill in shear and compression?
Mike McCann
MMC Engineering
In some of the products, the cores are partially filled, which contributes to the strength of the entire wall panel and cannot be neglected if it is justified by actual panel tests.
I do not agree with the general concept, but the test results for certain products do take advantage of the over-all conservative limits imposed by traditional old test results of lower quality products. The manufacturing process of modern units has outstripped the traditional properties and the outmoded ASTM C90 requirements since it is now impractical and not economical to make weaker units that comply with the minimum standards.
Dick
http://www.cbisinc.com/korfil.html
Or like the examples I've attached:
Those are a couple of the products I was familiar with in the 1970's.
One used the very traditional CMU old-fashioned and inefficient shape that suffered from "thermal short circuiting", but did test adequately from a structural standpoint.
The other was a lighter insulating insert that was made for a unique shaped CMU meeting ASTM requirements (single aligned cores with recessed webs) that was much more thermally efficient, but the cost of different CMU molds ($10,000+ per size for each producer) did not allow it to be economically viable. The structural tests were very good, especially with a center insert grouted on both sides.
The results of the wall structural tests did show the ability of grout and insulation to produce a wall strength equivalent or superior to the "common" units made for minimum code standards. Incidentally, the CMUs used in the wall tests did exceeded ASTM minimums because minimum strength units were not available from any supplier, but the grout used was made to ASTM minimum strengths with 8" to 11" slump with strengths less than the f'm of the CMUs.
Dick
Apparently there is a different type block with a double face on one side with a separate core area for insulation, but not in the main core used for reinforcing and grouting.
I still do not personally like the use of compressive materials (especially EPS foam) in grouted cores, but the ultra-conservative test reports of full wall sections cannot be ignored.
Dick
