Millturn milling feed in post
About feedrate in millturn milling:
I have tried to change default F to mom_feed_rate_per_rev in post-processor, and program from ipm to ipr, because it is normal to use inches per-rev as lathe feed, but the numbers are not what I wrote in the program.
I know there are some kind of calculations and choices of IPM IPR FRN DPM in UG CAM, how can I fix this ?
I was also thinking that why not use ipm as feed in DMG millturn
and put G94(this is for turning), but I can't find G194 in G-code list, can I try G94 instead of G194 ?
thank you anyway
thank you anyway
