Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Keep up the very good job that you and your team are doing. This site has replaced my morning cup of tea as a must have/do!!!..."
Geography
ErnieLamproPE (Civil/Environmental)
20 Apr 12 10:19
Can someone provide a reference to the theory of well construction? I am looking at the installation of methane monitoring wells and want to feel comfortable about where the screen should be placed.
cvg (Civil/Environmental)
20 Apr 12 11:49
you need a geologist to review the drilling logs and he can direct the driller to install the screen to only capture the aquifer(s) that you want to monitor.
http://www.usbr.gov/pmts/geology/geolman/chap09.pdf
also try the Ground Water Manual by Bureau of Reclamation
hhes (Civil/Environmental)
20 Jun 12 10:04
Consider, too, how you want to construct the well so that the sampling personnel do not have an excessively long purge time. If these are shallow probes, you can get away with just a small diameter (1") probe. If these are deeper, you may want to consider the installation of some smaller tubing inside the probe that terminates at the screen depth and is connected to a petcock at the top of the probe. In a deep probe situation, you have a lot of stagnant headspace and ideally that would need to get purged to ensure an accurate reading at the screened interval. Depending on the pump rate of the instrument, that could take a while.
If you are near the water table, you want to ensure that the screen is long enough to not get flooded out due to seasonal water table fluctuation. If that happens, you will be monitoring the headspace above the water and not the unsaturated zone you are trying to.
26 Jun 12 16:23
Thanks for the help.
fattdad (Geotechnical)
28 Jun 12 8:14
methane rises, water falls when acted upon by gravity. As such, the strategy for well installations differ.
f-d
¡papá gordo ain’t no madre flaca!
Close Box
Join Eng-Tips® Today!
Join Us             Close
