Fire Pump Help
Fire Pump Help
I am not a pump person so would appreciate your inputs,
my client asked me to supply below pumps which seems to be unique,
any advises or vendor advises will be appreciated
UNIT NAME : EMERGENCY DIESEL FIRE PUMP
Flow per pump m3/h 736 (4)
Pump type Pull-out
Pump model (1)
Number of stages 1
Impellers type Mixed flow
Fluid : Seawater
Pump type Pull-out
Pump model (1)
Number of stages 1
Fluid : Seawater
RE: Fire Pump Help
http:
What is the pump discharge pressure?
RE: Fire Pump Help
I will check them
RE: Fire Pump Help
Just google vertical fire pump and you will find more than you can handle. Big time players such as Peerless Pump( Grundfos now), ITT / Gould, SPP.
RE: Fire Pump Help
You probably will need to look into use of a vertical turbine pump:
http://www.fmpump.com/resources/images/412.pdf
You can get UL/FM approved vertical turbine pump that meet your discharge and pressure requirements.
RE: Fire Pump Help
