Four Winding Transformer modelling
Hi
I am looking for a help in four winding transformer . Does anybody have equivalent circuit of a four winding transformer. Recently I came across a four winding transformer with the following specification.
22kV/690V/690V/415V
1MVA/1MVA/500kVA
4.48%/5.13%/7.18%.
I confirmed from the client and they said its four winding transformer but by looking at the rating and percentage imp , it seems to me it is three winding transformer but looking at voltage again it seems it is four winding transformer.
Can anybody highlight something about four winding transformers and how to model it . For example three winding transformer can be modelled with two - 2 winding transformer ?
I have also attached the nameplate details (? ) of transformer taken from single line diagarm.
htt p://files. engineerin g.com/getf ile.aspx?f older=26b0 7f4e-a062- 4201-b1ad- 64e8db7ed0 ff&fil e=four_win ding_trans former.bmp
Your help is kindly appreciated.
SImatic
22kV/690V/690V/415V
1MVA/1MVA/500kVA
4.48%/5.13%/7.18%.
htt
SImatic
RE: Four Winding Transformer modelling
If you just want to run some load flows and balanced short circuits, then you could get away with modelling it as three two-winding transformers.
It gets trickier if you want to calculate unbalanced faults. You'll definitely need more information to model the zero-sequence impedances (e.g. measured impedances with various combinations of open- and short-circuited windings).
For EMT studies, you'll need more information still.
If you can give impedances for all combinations of windings with their MVA base, I can try and give the mesh circuit.
regards
Simatic
