DTH Drilling Air Capacity Question
What kind of compressor (CFM,psi) should be employed to drill several 6.5" dia., 30 m. deep vertical bore holes in rock for the installation of ground anchors under a bridge. A track drill EMC 350 with an Air Rotary Head ARH 351 (Torque 270 kg-m) and a 5" down the hole hammer are to be used. I appreciate all your comments.
RE: DTH Drilling Air Capacity Question
21 m3 per minute and 21 bars
Thank you very much for the advice BigHarvey, it is well appreciated.
