how do you modify or remove array component from assembly
I have a couple questions using an array in an assembly in NX5.
If I want to modify the number of comonents or how they are arrayed, how do I do that.
Also I am trying to delete my array components and start something new, but when I select all the components and delete, they all go away except for one. I get the following error the following component could not be deleted: component name attemp to delete an array master component failed.
RE: how do you modify or remove array component from assembly
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.6, NX6.0.5, NX7.0.1, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.1
