Engineering reference problem. (SE ST2 MP12)
Hello, I'm doing a university project which will include using the options given in the tool > engineering reference, the problem I'm having is whenever I select any designer option nothing happens, nothing opens, and no error message either. I am running Solid Edge ST2 with maintenance pack 12 on Windows 7 64bit.
After some search I found that there was a similar problems for someone (except he had an error message) where Daemon tools were interfering with the program, so I did a full uninstall of both, solid edge and daemon tools (including cleaning the registries) and then running a full clean installation. Sadly that didn't solve the problem.
Didn't manage to find any other reason for this, so hopefully there will be someone here who might know the reason, and how to fix it.
Thanks.
