Composite position on non-patterned features
I have a threaded gland with a flange and a bore. I am trying to position the threads, I want the primary datum to be the flange and the secondary to be the bore. I want to then refine the orientation to the flange.
I want to use a composte position, but I am not sure if I can beacuse the feature isn't a pattern.
Is it legal to use composite position control on a non-patterened feature?
RE: Composite position on non-patterned features
First frame will loosely locate to [A] and [B], than second will tighten location to [A].
Haven't seen it done on threads (what are you locating; MD, PD?). So, I am really curious what others have to say.
It is the PD, we usually put an MMC modifier on the position so a functional gauge can be used.
|POS|Ø.010(M)|A|B(M) and refine by
|PERP|Ø.005(M)|A
SeasonLee
Frank
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
Fig.6-5~6-9, Fig.6-12, Fig.6-14 and Fig 6-15
SeasonLee
