Anorher User Opens Specification File and It Reads "Read Only"?
UG/NX 7.5 on Windows XP Dell Workstation.
I have saved all the models, model assembly, and specification drawing files correctly and then closed them all.
The files have not been statused in Team Center and the same files are not Checked Out by me.
When another user opens the files UG/NX states the files are "Read Only".
Can anyone shed any light on this?
Thanks for your help in advance.
RE: Anorher User Opens Specification File and It Reads "Read Only"?
If not, then your system's OS is controlling access to your files. You've got to set up your system so that files created by you can be opened and modified by everyone or else they belong to you and you alone. On Windows it's called 'Managing Permissions' so if it's not behaving as you expected I would check your Windows help for entries on setting and controlling permissions on files and folders (remember, you have to access to both the file and folder).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Could the "(Modified)" issue upon openning file per my other thread have something to do with this issue?
John R. Baker, P.E.
Industry Sector
Cypress, CA
If we get an answer I will post again what happened.
