Custom Made Lifting Device
Hi
I'm currently designing a custom made lifting device to provide better attachment during the lifting operation of a truck body. I picked up an ASTM A514 to be the best choice for the built up element (welded plates with a hook like shape). I selected that steel because of its high strength/weight ratio and relatively good toughness and weldability. However I'm not 100% sure if this is the best option or even if there are major drawbacks for using this material in this particular application. I really appreciate any comments regarding my choice. Thanks
RE: Custom Made Lifting Device
OR buy one!!!
Test it at 125% of the max design load.
Then paint the max design load on the weldment......
You haven't done a very good job of describing your lifting device or how it is going to be used. Remember that drawing something with a CAD program is a lot different than doing a good job of designing it and knowing how to build it, and is far short of doing a good stress analysis on it. Good clean details and welding, without stress raisers, etc., is all important. And, higher strength material will not overcome a poor design, which is difficult to build. Also, a few extra pounds of material on something like this is usually not the end of the world. And, you picked up "an ASTM A514," but you don't say if that is a quart or a pound or a plate or a shape, but in any case that material does require some special attention to welding. All-in-all it sounds like you should talk with one of your senior engineers about what you are trying to do. They can help you, and they should know what you know and what you don't know about this kind of design, so as to help keep your company out of trouble.
