How to calculate the Rectified DC voltage from AC servomotor
Dear Sirs
I am working with a Control Techniques Permanent Magnet AC Servo Motor. I am looking to feed the motor through a full bridge rectifier (Six Diodes) and would like to workout what the rectified DC voltage will be. On the data sheet the the Ke(voltage constant) is given as Ke = 98Volts RMS/Krpm.The rated speed of the motor is 3000RPM. I have no idea if this is volts line to line or line to neutral. I am a mechnical guy and am quite new to this any advice would be useful.
Many Thanks
Many Thanks
RE: How to calculate the Rectified DC voltage from AC servomotor
This link might be of interest.
I am not feeding the servo with DC. We have a motor/generator rig setup. Wereaby one of the motors is used as a generator that is driven by the other motor. It is the generator side that is being fed through a rectifier. I could give a full description of why we are doing this but I didn't think i was relevant. My question was simply about calculating the rectified DC value.
If you want to get in to the maths, this paper from CERN gives some good notes on rectifiers from single diode half-wave types right up to multiphase designs, then on to thyristor-controlled types.
http://ww
and found on page 10 a class of motors with a listed Ke of 98Vrms/krpm and Kt of 1.6 N-m/A.
The Ke and Kt for a motor are really the same thing (or conservation of energy would not apply). In consistent units, they will have the same numerical value. The consistent SI "analytic" units are N-m/A(rms) for Kt and V(rms) / [rad/sec] for Ke. The document gives the Kt in these units, but we will have to convert Ke.
98 (Vrms / [krev/min]) * 1/1000 (krev/rev) * 60 (sec/min) * 1/2Pi (rev/rad) = 0.93 (Vrms / [rad/sec])
This does not match the value of the 1.6 N-m/Arms spec. But if you multiply it by 1.732 (sqrt(3)), which is the factor for converting phase/neutral voltage to phase/phase voltage in a 3-phase Y-circuit, it does match. (In a Y-circuit, line current equals phase current.)
So it looks to me that the Ke spec is for phase/neutral voltage per unit speed. Anybody agree/disagree?
Firstly thank you for to ScottyUK for the link to the paper.
cswilson i worked through the same calculation that you have done and came to the same conclusion. So i think you are correct. Although possibly someone could verify it for us.
98V(rms)/Krpm
98/1000 = 0.098V(rms)/rpm
1 rpm = 0.104719755rad/sec
1/0.104719755 = 9.54939669 rad/rpm
therefore 9.54939669 * 0.098=0.936 Volts(rms)/rad/sec
0.936 * sqrt3 = 1.62
