Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I signed up to your site to get help with a problem and I am so glad I did. I found the help I needed immediately. Thanks to all who contribute to your site..."
Geography
LuckyG12 (Petroleum)
19 Apr 12 5:38
Hi all,
I have been searching in vain for the past few months for a way to predict the final distillation curve of two blend petroleum products.
Is there a computer programme or known equation which could help me predict what the curve will look like from two components?
Any help on this one would be greatly appreciated.
Cheers
rutherford703 (Chemical)
27 Apr 12 10:24
I believe PRO II can predict the distillation curve for two blending petroleum products. Maybe Hysis can do it too.
thecaptin (Chemical)
14 May 12 10:32
what about of any equation to calculate the blend of gasoline?
poli60 (Chemical)
14 May 12 11:32
Just for quick estimate you can linearly blend the single component distillates at the same temperatures: for example
- 2 components (A,B);
- blend composition, mass (or volume) fractions: xA, xB (xA+xB=1);
- distillation points, mass (or volume) fractions: D1A, D2A.....DnA and D1B, D2B,....,DnB (at T=T1, T2,...., Tn °C).
Results: DiBLEND = xA*DiA + (1-xA)*DiB (for i=1...n)
This approach were used in old blending/linear programming tools, not yet linked to simulators. Results are not very bad... only when the temperature ranges of the components are not very different.
The alternative (rigorous) approach consists in putting the two (or more) component distillation curves and mix them in a Process Simulator (HYSYS, UNISIM, PROII, WINSIM.....)
Close Box
Join Eng-Tips® Today!
Join Us             Close
