Clear water influent to sand filter, yellow water effluent
How is that possible?
We separate water and crude oil from the oil wells.  The separated water enters the clarifier with ~150 ppm oil and visible suspended solids.  The water from the clarifier is clear color, no SS and 0 ppm oil.
The water then passes through the sand filter and turns yellow.  We had a process upset which may have contaminated the filter.  I do not think it is channelling in the filter.
Does anyone have any thoughts or suggestions as to why the water turns yellow?
RE: Clear water influent to sand filter, yellow water effluent
You do not list much as to the process parameters. One would suspect that a dissolved material such as iron may be oxidizing and precipitating from solution.
Should be easy to have a lab test done.
