Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site has saved me hours of work that I cannot begin to express my satisfaction..."
Geography
valya111 (Automotive)
18 Apr 12 14:33
hi.....
       i am having two plates of size 2m(length)*0.5m(width)*0.2m(height) each. and i m going to join them
(2m*0.2m cross sectional area of plates in contact) by three large sized bolts of length 1m and dia 80mm with some preload.
this assembly is then subjected to alternate external load at left and right side plates in vertical direction( over area 2m*0.5m of each plate).
the requirement here is that the two plates should not separate from each other and also i have to determine the required preload in all bolts which will sustain external 10000T load.
my question is what should i check in simulation results so that i can able to say that these plates will not separate and can sustain external high load and select bolt material accordingly.
please help...........
kellnerp (Mechanical)
19 Apr 12 9:39
Sounds like a text book homework problem.
You could draw a diagram. That would help.
If you are talking about separation, is this elasto-plastic?
If you are talking about alternating loads, is this fatigue?
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
Bouing (Mechanical)
25 Apr 12 15:50
Find your max load and do a static analysis with the preloaded bolts.
After that see the deformation with a big magnification factor (around 100) and you'll see if they separate and by how much and if it is everywhere or not.
Close Box
Join Eng-Tips® Today!
Join Us             Close
