Nastran DMP
Nastran DMP
Nastran DMP
Hello everyone,
My question is about the MSC Nastran DMP
(Distributed Memory Parallel)
I have a model with 400000 Elements and 4.5 Million DOF's.
And I also have about 4000 loadcases. The solution is linear static, SOL 101. One LC takes about 6 minutes with DMP module.
What is the fastest way to solve these 4000 LC's with a 24 core, 64 bit server?
Do you have any advice about processor, memory, bulk file settings? Should I distribute the LC's per 1 core, or use all the cores for 1 LC.
Thanks in advance for your comments.
RE: Nastran DMP
running one loadcase per core would be the best imo. but you will probably need a scheduler for that or a script so that two won't be running simultaneously (i.e. fighting for resources on the same core)
