Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It's fun to see others going through the same stuff I did and be able to help. It's also a way for me to stay sharp and not lose the stuff I've learned..."
Geography
abbver98 (Mechanical)
18 Apr 12 11:06
ASTM A182 para 6.2.1 : "Liquid Quenching—When agreed to by the purchaser,liquid quenching followed by tempering shall be permitted provided the temperatures in Table 1 for each grade are
utilized."
Does this concern also F22 Class 3 for which "anneal" or "normalize and temper" is listed ? I n other word Liquid Quenching and tempering is accepted for this grade.
Application : pressure vessel.
Thanks for your contribution.
metengr (Materials)
18 Apr 12 11:58
Yes, but only for the normalize and temper heat treatment. Anneal is furnace cooled.
18 Apr 12 18:11
metengr,
you mean that F22 Class 3 can't be Liquid Quenching and tempering but normalizing and tempering. right ?
metengr (Materials)
18 Apr 12 18:39
abbver98;
No, this is not what I stated. Normalizing means air cooling. For heavy sections or thick sections of materials  A 182 by virtue of this paragraph permits by agreement between the purchaser and the supplier, liquid quenching to assist in cooling heavy or thick sections that otherwise would not be adequately air cooled to produce a normalized structure before tempering. So, any of the materials in Table I can be liquid quenched by agreement or if it directly states liquid quenching as in the table.
billbirk (Industrial)
23 Apr 12 11:22
Is the heat treatment for F22 Class 1 annealed only?
And, is the heat treatment for F22 Class 3 normalized and tempered?
hsemus (Petroleum)
4 May 12 9:17
F22 material can be liquid quenched and tempered  inorder to achieve the mechanical properties.
The temperature can be  alter according to your mechanical property requirements( yield + hardness ). Always check the microstructure after heat treatment for more uniform structure.
Close Box
Join Eng-Tips® Today!
Join Us             Close
