Boolean operation for hole
Could someone please explain why the hole operatio has the option to create a hole without using the subtract boolean operation? I've never figured out why.
Si
Si
Best regards
Simon NX7.5.4.4 MP5 - TC 8 www.jcb.com
RE: Boolean operation for hole
This can be useful when the target body has not yet been specified or is not yet present in the part, but your hole templates are ready.
Positive holes are solid bodies, and are created from the Hole dialog box using None for the Boolean and Along Vector for the hole direction.
Positive holes can include symbolic (internal) threads, which will later update correctly when a target solid body is available and specified for the hole, and the Boolean is changed to Subtract.
Thank you...
Using NX 8 and TC8.3
NX 6.0.5.3 (NX 8 Testing)
Windows 7 64
Best regards
One application which comes to mind where this can be useful is when designing something like a hydraulic manifold where you drill a series of holes into a block of steel which creates a network of passages and ports. While you could do something like this by sketching profiles and doing extudes or revolves, or even defining a series of primitive cylinders (now that I can parametrically control their origins and directions) have a model consisting of features which can easily be specified in terms which would directly relate to the manufacturing process which will be used to actually create the product does provide a certain level of elegance as well as to clearly establish your design intent in a manner easily understood by those responsible for the manufacturing process.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
