Does each computer has a unique identifier?
I am trying to write a program which can only install in some computers. Does each computer has a unique identifier?
RE: Does each computer has a unique identifier?
1. Use conditional if statements (#If). The following is an example of what I know is supported:
#If Mac Then
'. Place exclusively Mac statements here.
#ElseIf Win32 Then
'. Place exclusively 32-bit Windows statements here.
#Else
'. Place other platform statements here.
#End If
2. Use SysInfo control (SysInfo.ocx). Example:
Dim MsgEnd As String
Select Case sysDetectOS.OSPlatform
Case 0
MsgEnd = "Unidentified"
Case 1
MsgEnd = "Windows 95, ver. "& _
CStr(sysDetectOS.OSVersion) & "(" & _
CStr(sysDetectOS.OSBuild) & ")"
Case 2
MsgEnd = "Windows NT, ver. " & _
End Select
MsgBox "System: " & MsgEnd
Note: sysDetectOS referenced to a SysInfo object.
TTFN
http://community.borland.com/article/0%2C1410%2C26040%2C00.html
Also,
ipconfig /all at the cmd prompt will show the physical address of the Ethernet adaptor.
TTFN
