Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I am very impressed with the site and have already recommended it to one of my associates. I was truly impressed with the quickness in which someone actually responded to my question..."
Geography
JennyNakamura (Structural)
17 Apr 12 21:33
Hi everyone,
When cofferdams or some other kind of stream flow diversion is required for bridge foundation retrofitting, are they designed by the engineer of record and shown on the contract drawings or are they designed by the Contractor (or his specialty engineer) like would be the case with scaffolding or falsework?
Thanks in advance...
davidbeach (Electrical)
17 Apr 12 23:11
Not a bridge engineer by any measure, but I've always been aghast at turning perfectly good, billable engineering work over to construction contractors.
bridgebuster (Civil)
18 Apr 12 7:08
NYSDOT leaves it up to the contractor. The thought being that since it is a temporary structure a contractor may have materials on hand or is more confortable with a particular type of system.
PEinc (Geotechnical)
18 Apr 12 10:13
The contractor's engineer usually designs the cofferdam.  That way, the cofferdam and bracing scheme will accommodate the contractor's construction methods.
www.PeirceEngineering.com
cvg (Civil/Environmental)
18 Apr 12 20:26
usually contractor designs. As the EOR, I usually give some minimum requirements or even a preliminary design to minimize the liability and to make sure each contractor is bidding a similar concept. contractor is then required to submit his final design for review by the EOR.
gwynn (Structural)
19 Apr 12 21:11
I agree with PEinc. As someone who spends most of my time doing construction engineering, even if the EOR supplies a design for cofferdams or other temporary works, chances are the contractor will have someone else redesign it to suit their preferred construction methods/available equipment/available materials. So if you do design it, be prepared to spend time reviewing alternate concepts.
23 Apr 12 13:03
When a contractor redesigns the cofferdam, in effect, the project owner is paying for two designs - one of which isn't needed.
Close Box
Join Eng-Tips® Today!
Join Us             Close
