Proof Test - UG-101
Proof Test - UG-101
Hi All,
Can i use UG-101(M) to calculate MAWP of modified "T" (Fitting) ID, which i want to use in pressure vessel?
If yes, code reference and what dimensions, NDE, report require.
Can my sister company use the same proof tested report to use modified fittings to their vessel?
Your promot reply will be highly appreciated.
Thanks in advance
BPVN
Thanks in advance
BPVN
RE: Proof Test - UG-101
