Can't pick data when "See-Thru" mode is active
Can anyone else confirm that when "see-thru" mode is active you can't pick data that is inside/hidden by a solid. I can pick the data if I make geometry translucent, but I thought that "see-thru" mode made things translucent also.
John Lackowski
NX Support
Win 7 64bit NX 7.5.4.4 TC 8.3.1.1
RE: Can't pick data when "See-Thru" mode is active
But even then, you'll still need to make sure that the selection option 'Allow Selection of Hidden Wireframe' is toggled ON (when the icon is selected it's toggled ON):
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
John Lackowski
NX Support
