cyclic test results for moment connections
In IBC 2000 for Special Moment Frames reference is made to AISC's Siesmic Provisions part I and III.  In order to design Special or Intermediate Moment Frames column to beam connections, cyclic test results are required for similar projects.  Where are the test results available?
RE: cyclic test results for moment connections
FEMA350 is a design guide for steel frames and the moment connections.  You can obtain a copy (free) by calling 1-800-480-2520.
