How to model 2 dimensional airfoil for flutter analysis
I want to model an airfoil which is 2-d (attached) for both flutter and static aeroelastic analysis, the mass is given per unit length so i can obtain stiffness of the spring (in the figure) K_h and K_alpha from w_h and w_alpha (frequencies) which are again per unit length (i call this as distributed spring). So how should i model this airfoil.
I know that we need a 3 dimensional body for flutter analysis, in such case how should i consider the distributed spring stiffness and what should be my span??
RE: How to model 2 dimensional airfoil for flutter analysis
