NB Random on Random
NB Random on Random
I think I have this right, but I would appreciate to get this verified.
I have a RoR Vibration Specification from a Tracked vehicle. Several Phases are defined with up to 5 Narrowbands for each Phase.Each NB defines a sweep BW which is half of each BW. Does that mean that the sweep BW is swept inside the BW for each Phase?
An exmaple: One Narrowband is from 18-30 Hz where the sweep BW is defined as 6 Hz. Does that mean that the 6 Hz narrowband could be anywhere within 18-30 Hz?
Thank you for any enlightment.
