synchronous timing belt torque
I want to replace a #40 single strand roller chain with a synchronous timing belt, imperial pitch "H", 1" wide.Will it be strong enough? Its 1:1 ratio 2.250" spocket (15 tooth). Its a conveyor driven by a speed reducer gear box output 60 RPM. The output torque of the speed reducer is listed at 440 in. lbs. Thanks for any help.
RE: synchronous timing belt torque
Almost certainly the belt manufacturer's catalog will guide you through the calculations to confirm.
You should be able to check the manufacturer's catalogue and/or website to see the torques and speeds of their drives. That should answer your question.
