Why are Torus features so slow in NX?
Hello everyone,
Why is it that revolved toruses/rings are so much slower to create and regenerate than than other features?
The attached image shows two versions of a feature pattern, the first is a revolved cube, the other a revolved circle. While the first one takes a blink of the eye to regenerate, the circle version needs 35 seconds! And if you suppress and unsupress, it will take 1 minute and 45 seconds to display the torus pattern!
In assemblies this causes another problem that if a component consists of a pattern of toruses, it dramatically slows down assembly operations, like adding assembly constraints and modifying those constraints.
Out of curiosity I created the exact same part in Solidworks, it regenerated instantly, and suppressing and unsupressing took about 2 seconds. So obviously this is a problem exclusively in NX and nothing to do with the kernel.
My machine specs are not inadequate and I have no problems with other types of features. Torus features is a major problem, what can be done to speed them up?
NX8 E8800@3.7Ghz 6GB Quadro2000
RE: Why are Torus features so slow in NX?
the new pattern feature can handle this,but I would use Instance Geometry in this case,( individual bodys ), give it a try.
It's not the pattern that is the issue, the pattern only exaggerates the problem, the problem is the way NX creates the revolved torus feature.
Anyhow, isn't this related to the graphics card? Isn't Quadro 2000 enough to handle Ultra Fine faceting?
Granted, when doing high-quality rendering using the graphics hardware such as in Studio mode, you may wish to use a higher resolution. This is why we've provided different settings, Shaded Views versus Advanced Visualization Views. So set these accordingly.
Of course, the reason that you noticed this with the torus is because the shape of a tori is one the most complex that there is when it comes to creating facets.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Preferences - Visualization - Faceting, In the bottom there is an option "Show facet edges", turn that on and then try the different resolutions. Maybe you need to regenerate the graphics after changing the resolution, View - Operation- Regenerate Work.
And btw,
Tomas
As for Solidworks, I cranked the "Image quality" up to full, with a deviation of 0.0462. But the torus still regenerates without the slightest delay, even when zooming up very close. The same torus will regenerate much, much faster in Solidworks than in NX. Maybe the reasons are:
-Solidworks uses a clever algorithm.
-NX doesn't fully utilize the graphics card.
Another problem is the issue of faceted curves. In NX, the faceting of curves is related to the resolution of shaded views. But in Solidworks, all curves are display super smooth regardsless of the faceting of shaded objects. See attached images.
htt
htt
I can tolerate low faceting of shaded objects, but I cannot tolerate jagged curves. Is there a way to improve the display of curves in NX without compromising the performance?
Preferences -> Visualization -> Line
...and set the value labeled 'Curve Tolerance'.
Now there are some other things that needs to be considered. When working with an assembly, be careful since by default (starting with NX 7.5) the display of solid/sheet models are being done using Lightweight (faceted) representations so no matter WHAT resolution that you chose for displaying 'Shaded Views' or the 'Curve Tolerance', it will have no effect whatsoever. These only apply when working in a piece part or in the Work Part when working in context of an Assembly or if the Assembly was loaded using Exact representations.
And if you zoom in on a model which is not faceted and you see 'faceted' edges/curves, simply hit the 'Update Display' button.
And there is one more thing that you can do if you're really looking for the best possible display of whatever and that is toggling ON the 'Curve Antialiasing' option found on the...
Preferences -> Visualization -> Visual
...dialog in the section labeled 'General Display Settings'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
However, there is one issue remaining, and that is in the case where you have the shade faceting set to "Standard", then when you zoom in close to the torus, the torus will appear faceted. Now when using the "Update Display", it took 32 seconds to display the torus. In Solidworks, the torus looks smooth no matter how close you zoom in, and you don't have to do anything special to update the display, and it regenerates instantly. For the moment, in NX, I'm getting around this by setting the faceting to "Extra Fine", this way the torus will still look acceptable when zooming in close and I never have to use the "Update Display" button.
Anyone who sets tolerances and resolutions as high as you're doing has NO right to complain about performance. We have porvided you the tools and options to get the best performance possible. If you don't take advantage of them after being told what to do, you're just wasting mine and everyone else's time answering your questions. You've obviously come here with an agenda. If your intentions are to look for and then bitch about one thing after another, please go away. The Eng-Tips Forum was not established for this sort of activity.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Tim Flater
NX Designer
