Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thank you. It's already helped me greatly, and I enjoy just reading the inputs from the other members..."
Geography
priyainuk2009 (Geotechnical)
16 Apr 12 5:52
We have installed Vibrating Wire Piezometer in Underground Metro site construction at 25m depth from ground.
The initial reading recorded was 0.177MPa on Nov-11 & present reading is 0.159MPa.As per AAA levels the 'Alarm Level' proposed for change in pressure is 0.20MPa. Our latest readings shows that change in pore pressures are very close to 'Alarm Level'.
What this signifies & how much impact it has on Underground Constructions?
Thanks in advance
Debasis
Ron (Structural)
17 Apr 12 18:55
If you don't understand the need or the results of a piezometer, why did you install them?
dgillette (Geotechnical)
25 Apr 12 11:02
Am I reading the numbers right?  If so, you've had a decrease of 0.018 MPa, compared to the alarm level of 0.2 MPa.  Should that be 0.02 MPa for the alarm level?  (Total overburden stress is only about 0.5, right?  I don't normally work in SI units, so I'm a bit awkward at it.)
Now, for your project, is a DECREASE in PWP a problem, or only an INCREASE?  Could be very different in effect.
Close Box
Join Eng-Tips® Today!
Join Us             Close
