Rectangular Array
Rectangular Array
Hi. I've recently began using UG NX 7.5 & I could do with some help in creating a rectangular array. Problem is, the parameters are only for XC & YC, whereas I would like to array along ZC. Any suggestions would be much appreciated. Please note, I'm an absolute beginner.
Thank you.
Judge.
Thank you.
Judge.
RE: Rectangular Array
Re-establish the wcs as before.
Other solution is switch to NX 8.
Thank you...
Using NX 8 and TC8.3
Thank you...
I haven't used pattern face before, but I'll investigate further.
Thank you
Judge.
