Pipes Welding
Pipes Welding
I need to weld 2 pipes like a T diam 1", sch40 carbon steel. A torque will be applied on it. what are the calculations to determine if the welding between the two pipes will be strong enough for the use?
RE: Pipes Welding
RE: Pipes Welding
Thanks for your help.
RE: Pipes Welding
Rod
RE: Pipes Welding
