Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site was well structured and I found what I was looking for in about 2 minutes. I am looking forward to participating with you in the future..."
Geography
waynethepain (Industrial)
16 Apr 12 3:34
Hi Guys,
I want to design a form that goes over the skin as it is low volume I was thinking CNC that will then be thermoformed but I do not want any sharp edges that may cause cuts.
The CNC inner pattern may change but the overall form will stay the same.
Has anyone done this before? Or has anyone got anymore ideas?
Thanks for the help,
Wayne.
patprimmer (Publican)
16 Apr 12 4:25
A slight hint as to numbers required and durability and environments it may be exposed to might help.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
16 Apr 12 5:27
Thanks for the reply.
Qty approx 100.
retail enviroment.
Cheers,
Wayne.
16 Apr 12 5:50
I still am quite confused about what you are really trying to do.
You want to CnC a shape then thermoform it.
From what you have said, I see no reason why you can't just cut the shape out of sheet and thermoform the sheet.
Pat
for site rules
16 Apr 12 5:57
I am worried about sharp edges as it is put up against the skin. Maybe I am on the right lines but I am just checking if anyone else knows of a better process.
Cheers,
Wayne.
Helpful Member!  patprimmer (Publican)
16 Apr 12 6:46
I still have no idea what type of plastic you intend to use. Many can be flame polished which will smooth off the edges
Pat
for site rules
16 Apr 12 7:01
Thanks Pat
Flame polishing is the peice of the jig saw I was missing!
Cheers,
Wayne.
Close Box
Join Eng-Tips® Today!
Join Us             Close
