ASTM A-106 GR B PROPERTIES...WHERE?
Hi everybody!!!
I`m looking for the density, thermal conductivity, specific heat for ASTM A-106 GR B. Do you know where I can find it?
Thanks!!
R
Thanks!!
R
RE: ASTM A-106 GR B PROPERTIES...WHERE?
At 70 deg F
Thermal conductivity is 34.9 BTU/hr-ft-oF
Thermal Diffusivity is 0.700
TD = TC/[density x specific heat(BTU/lb-oF]
You can solve for the specific heat.
Thank you very much. Just one question: in ASME section II part D can I find thermal conductivity and diffusivity at different temperatures?
Thanks!
