What is zinc plate with clear conversion coating??
right from the blueprint- -does the author of the print really have a grasp on this field?? zinc plate & clear chromate,aren't they two different processes- - I' lost on this......
RE: What is zinc plate with clear conversion coating??
The author appears to have a grasp on this field.  The author is asking for the piece to be electroplated with zinc, and then the zinc layer should be converted by immersing in a chromate-containing solution.
For more information, go to:
http://www.pfonline.com
and type "chromate conversion" in the search box.  You will get good information about this process.
