Copy and paste catia files
I work for one project office. We have some similar prjects. Often we need to take some project, make changes on them and make a new projekt with another name of them. Usually we do that we make a new from of product, put in all it's parts, rename it and save as in new folder. Later we must connect broken links an it takes lots of time. We try in windows explorer just copy and paste catia files in new folder, but when I open product, catia opens only product from new folder, all parts are old from old folder. I read some of catia uuid numbers. Is this issue becouse of this unique UUID numbers?
RE: Copy and paste catia files
Check please
http://www.eng-tips.com/viewthread.cfm?qid=198922
http:
h
or even better search in Google for:
site:eng-tips.com "about" search order in CATIA
Fernando
You can use also new from for all your CATProduct components from the very beginning and also Save management and Apply Pattern, the only problem is to rename instances (and this can be done with a macro, you can find it here in the forum).
In this way you can avoid a lot of unnecessary work.
Fernando
