Fixture for mounting lens
I am running into a problem on assembly line of a product which involves gluing a triangular shaped prism on a metal surface using an adhesive. The challenge is to make a fixture so that the prism could be mounted flat against the metal surfaces.
Thank you for any suggestions.
RE: Fixture for mounting lens
Dan - Owner
http://www.Hi-TecDesigns.com
