nx7.5 component array
I have a small assy in nx7.5 and want use the component array.
I want to array to screws constraint positioned on feature arrayed holes. Now I want multiply them with the component array. I can select the two screws but only one screw is arrayed. Is there a trick is it a limitation on one component?
sorry new in NX
regards
Erwin
RE: nx7.5 component array
Could you provide at least a picture of what it is that you're trying to do (all I need to see is the model with the Hole Array as well as one set of screws assembled as desired).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Still wondering.
thx
sorry new in NX
regards
Erwin
John R. Baker, P.E.
Industry Sector
Cypress, CA
