Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...If there has ever been a justification needed for access to the net during working hours, just referring to this site should suffice. Fantastic!..."
Geography
I'm having problems getting my Mosfet to turn fully onHelpful Member!(2)
small1timmer (Mechanical)
14 Apr 12 3:36
I have been trying to get the right voltage to my mosfet so it works right.  I need it to open up all the way.  Can only get it to come on just a little.  I have included a diagram so you can see what i'm doing.  5 volt source comes from 12 volt source via a positive voltage regulator.  All power comes from a bank of 12 volt batteries.  This is suposse to run my DC motor for me.   Motor has 1 ohm of resistance.  I have tried removing the 316 ohm resistor to get more volts to the Mosfet gate but it only helped a little.   Getting so fustrated with this simple little circuit.   Feel free to make up a new diagram for me with new resistor values or just let me know what they should be.  thanks  guys.
IRstuff (Aerospace)
14 Apr 12 11:24
Proprietary schematic format is pretty much useless for anyone else.  Picture is better. What does the datasheet say?
TTFN
14 Apr 12 21:06
sorry.  here is a pdf of the schmatic.  the resistor are labled.  maybe you can just tell me what they should be or if the positive volts have to be combined.
Helpful Member!(2)  OperaHouse (Electrical)
15 Apr 12 5:00
The problem is obvious. Once the FET turns on the voltage on L1 subtracts from the gate drive.  The load should be on the + supply side of the fet.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
