Tensile Test Simulation
Hello everyone,
I would like to simulate a high velcity (500 mm/s) Tensile Test of a polymer (Polyurethane). There are 2 parts, one is fixed and the other one is moving. The problem is that the Abaqus/Standar abort at about 35%.
I see a node of one part is locked in the other part (image attached).
What can be happening?
Model Characteristics:
.Static,General
.Surface To Surface (I tried both formulation and both method)
.Tangential behaviour-frictionless
.Normal behaviour-hard contact_default
Thank you in advance for your help!
Bruno
.Static,General
Bruno
RE: Tensile Test Simulation
HTH,
Dan
Han primo incensus
Is it posible to solve an overclosure in Explicit?
Bruno
