Measure bodies
Measure bodies
Hello everyone
I am use analysis--measure bodies to get center of mass of a tapered body.
Its a multibody part.
In the information file,it gives me the values and error estimates.
The error estimates values are in thousands which made me approach this forum...:)
Date : 4/13/2012 9:47:54 AM
Measurement Mass Properties
Displayed Mass Property Values
Volume = 67858.10989569816 in^3
Area = 229256.34693012343 in^2
Mass = 19197.05928949301 lbm
Weight = 19197.05928949301 lbf
Radius of Gyration = 268.23425597988 in
Centroid = 0.00000006766, 409.14083502539, 5.08644062443 in
Detailed Mass Properties
Analysis calculated using accuracy of 0.99000000000
Information Units lbm - in
Density = 0.28290000000
First Moments
Mx, My, Mz = 0.00129887103, 7854300.86773500030, 97644.70223961631
Center of Mass
Xcbar, Ycbar, Zcbar = 0.00000006766, 409.14083502539, 5.08644062443
Moments of Inertia (WCS)
Ix, Iy, Iz = 4594076121.81324480000, 4728866.71545003540, 4591660862.09269330000
Moments of Inertia (Centroidal)
Ixc, Iyc, Izc = 1380064242.26730700000, 4232202.73521834610, 1378145646.52698730000
Moments of Inertia (Spherical)
I = 1381221045.76475620000
Products of Inertia (WCS)
Iyz, Ixz, Ixy = 57074532.32435357600, 0.37765596938, 0.46118485916
Products of Inertia (Centroidal)
Iyzc, Ixzc, Ixyc = 17124097.31423184600, 0.37104933899, -0.07023632060
Radii of Gyration (WCS)
Rx, Ry, Rz = 489.19469685695, 15.69499507060, 489.06608693092
Radii of Gyration (Centroidal)
Rxc, Ryc, Rzc = 268.12190635878, 14.84792888050, 267.93546704505
Radii of Gyration (Spherical)
R = 268.23425597988
Principal Axes (Direction vectors relative to the WCS)
Xp(X), Xp(Y), Xp(Z) = 1.00000000000, 0.00000000277, -0.00000021808
Yp(X), Yp(Y), Yp(Z) = 0.00000021810, -0.01246083498, 0.99992236078
Zp(X), Zp(Y), Zp(Z) = 0.00000000005, -0.99992236078, -0.01246083498
Principal Moments
I1, I2, I3 = 1380064242.26730700000, 1378359043.64586830000, 4018805.61633741950
Error Estimates
Volume = 37.47378610535
Area = 1.70501403591
Mass = 10.60133408920
Moments of Inertia (Spherical) = 0.45207876192
Center of Mass = 8683.37543481869, 13020.81411574129, 8737.29849048585
Moments of Inertia (WCS) = 29544060.32917690300, 20663990.09437890400, 29455451.10679721800
Products of Inertia (WCS) = 17010880.68397417700, 16944651.08697374900, 20519436.68664599600
Anyhow I will be using the cg values in my calculations.
Your help is appreciated.
thanks
First Moments
Center of Mass
R = 268.23425597988
Principal Moments
Error Estimates
thanks
RE: Measure bodies
Since these numbers appear quite large (almost 10 tons and 1600 square feet in area) I have to ask, how far away from absolute zero (XYZ) is the farthest point on the model?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
RE: Measure bodies
nx7.5
RE: Measure bodies
RE: Measure bodies
I guess there is a problem finding CG in NX for Large models in sheetmetal.
RE: Measure bodies
RE: Measure bodies
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: Measure bodies
RE: Measure bodies
Actually the values are correct, it's just that they're labeled incorrectly. Once you know what these numbers really represent, their magnitude is actually quite reasonable.
There's no problem with the labeling of the actual measurement results only with some of the 'Error Estimates'. Taking the example results from your original post and applying the correct label, would have now looked like this (corrected labels are in Italics):
Error Estimates
Radii of Gyration (Spherical) = 0.45207876192
Moments of Inertia (Centroidal) = 8683.37543481869, 13020.81411574129, 8737.29849048585
Principal Moments = 17010880.68397417700, 16944651.08697374900, 20519436.68664599600
The status fo the actual software fix will be the next full release of NX, which is planned for later in the year (and which beta testing started this past Monday).
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: Measure bodies
so i need to read error in th mass as error in the inertia...yes it males sense....its like .2% error...
thanks john
RE: Measure bodies
www.nxjournaling.com
RE: Measure bodies
Some of you may not be aware of this but we provide the option to 'localize' (i.e. Translate) the content of the NX dialogs, menus AND listing windows so that we can offer NX in several different versions based on the language of the user. Currently we support 10 languages, in addition to English.
However, the scheme that we use to do this, which BTW is done 'on-the-fly' (even the English version of NX is 'translated' from ALL 'UPPERCASE' to the 'Mixed-Case' that you see when running NX), requires that we know upfront all of the unique words and phrases used in NX so that we can then have the experts create the necessary 'look-up' files where NX will find the properly 'translated' words and phrases in whatever language was chosen when the software was installed or NX was told to run in. The original 'source' files which are referenced are not allowed to be changed once a version of NX has been released. This is why some PR's have to wait until the next release because it required changing the text found in some Dialog, Menu or, as in this case, the Listing Window. Even planned enhancements which went into say NX 8.0.1.x or is going into NX 8.0.2.x, we had to know ahead of time all of the unique words and phrases which these enhancements will introduce into NX so that we can release a reference file with NX 8.0.0.x which will not need to be maintained, 11 times over. And the real kicker is that we allow customers to edit these files if they wish to tweak them or to accommodate them running say an NX Open program, with it's own unique menus and dialogs, written by a multinational company who then wants their employees in different countries to use the same software but running in their local languages. So you can see if we were to change these 'translation files' with ever MR or MP that we sent out, how this could put quite a burden on some of our largest customers, to say nothing of the many small companies in places like Mexico, Brazil, China, etc which is using NX in a local language.
Anyway, I hope that explains why we can only 'fix' this in the next full release of NX, which will be available later this year.
John R. Baker, P.E.
Industry Sector
Cypress, CA
