Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks! Awesome group. I put out a simple question in the access/vba forum that I couldn't find answered on technet or anywhere else on the web and it was answered the same day!!..."
Geography
Clymber (Mechanical)
13 Apr 12 8:42
I recently started a new job, where the AutoCAD software defaults to "AutoCAD Architecture" instead of the plain vanilla AutoCAD (v. 2012).  As I am a mechanical engineer and not an architect, I prefer the familiarity of the basic AutoCAD layout.
I discovered by selecting OPTIONS -> PROFILES tab, I could select the base AutoCAD profile and correct the problem.  However, I need to do this every time I re-open AutoCAD.
Is there a way to fix this permanently?
Thanks in advance,
Brad
francesca (Civil/Environmental)
13 Apr 12 21:26
You want to change the workspace, not the profile. The little gear in the lower right corner. For vanilla AutoCAD you want "2D Drafting & Design." Or you can go to the Start Menu and pick "Open As AutoCAD" and drag & drop onto your desktop; that will always open in the right profile.
chicopee (Mechanical)
7 May 12 22:21
Was the profile that you selected "set current" because the file should save in that selected profile.
Lizard7709 (Civil/Environmental)
16 Jul 12 22:20
Right click on the shortcut you use to open autocad and select properties. Where it says target it will have something along the lines of
"C:\Program Files\Autodesk\AutoCAD Architecture 2012\acad.exe" with extra stuff at the end.
Delete the extra stuff at the end and then give it a go with setting your profiles.
We had updated to 2012 from 2009 and it has been a pain. With 2012 when I go to "classic mode" the detail component manager is no longer available. :(
Close Box
Join Eng-Tips® Today!
Join Us             Close
