Design Depth of HDPE Storm Pipe
I have a design spec of HS-25. Based on an axle load of 40,000 #, what is the depth at which I should install my 36" HDPE storm piping. How do I translate the axle load to the allowable load for the pipe?
thanks,
JEB777
thanks,
JEB777
RE: Design Depth of HDPE Storm Pipe
What would you be doing, if you knew that you could not fail?
