Split Body splits everything!
The Split Body tool is lacking in the ability to allow the user to choose which bodies will result from a split operation.
Often I have a shelled object on which I want to create a split body on ONE SIDE ONLY. But the Split Body tool creates a split body on both sides! Therefore I need to either create a surface first, then use the surface to split the body on one side, or use the Unite tool and combine the unwanted split body with the main shelled body. Either way is a problem because you need to create an extra feature which (1)causes more work, (2) creates extra clutter in the part navigator and (3) will complicate the rebuilding process if the sketch that creates the split body is changed.
Please refer to the attached image for how it's done in Solidworks. No issues at all there. A shelled cube is being split with a circle sketch. During the split operation the user can select which bodies he wants the create from the split operation. In this case the user selects the front split body (body 3) and ignores the split body in behind, thereby creating just 2 bodies in total instead of 3. This is very powerful and intelligent.
Is there something I've overlooked in NX?
RE: Split Body splits everything!
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.6, NX6.0.5, NX7.0.1, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.1
However, CNSZU seems to feel that his productivity will go to hell if he has to create ONE extra feature.
Productivity is NOT measured with a stopwatch. It's measured with a calendar.
John R. Baker, P.E.
Industry Sector
Cypress, CA
As for not specifying that I'm using NX8 is because I assumed that since I've mentioned what version I'm using before on this forum, that it would be superfluous. However, I'm going to remedy this by specifying it in my signature.
NX8
I'm pretty sure John is not keeping a list of who uses what version of NX...
NX 7.5
Teamcenter 8
John R. Baker, P.E.
Industry Sector
Cypress, CA
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
John R. Baker, P.E.
Industry Sector
Cypress, CA
While on the subject: what hardware info would you like to see next to the software?
NX 7.5
Teamcenter 8
Best regards,
Michaël.
Win 7 64 bit
Best regards,
Michaël.
Win 7 64 bit
Dell Precision T7500
Intel(R) Xeon(R) CPU X5650 @2.67GHz
24.0 GB
NVIDIA Quadro 4000
NVIDIA Tesla C2050
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
Now if the discussion goes to such things as performance, graphics issues, part file size problems, etc, then some inquires may be appropriate as to your CPU configuration, memory, graphics card, etc. However, since the primary business of Siemens PLM Software is supplying SOFTWARE solutions and that this is a UG/NX forum, at a minimum we need the version of the NX software which you were using when you encountered the issue that is being discussed, whether you were working in a managed mode (ie, using Teamcenter) and on what brand of OS is your software running (Windows versus Linux versus MacOS).
If those 3 pieces of information are always present, as would be the case if you're using the signature feature and had included that information, along with whatever personal/employer information that you're comfortable with providing (and is allowed by the Eng-Tips powers-to-be), then that should be fine.
John R. Baker, P.E.
Industry Sector
Cypress, CA
