Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have been a grateful member of this site for several years. I love this site and refer everyone to it!..."
Geography
duongwe (Mechanical)
12 Apr 12 20:50
I have read some book i see TIG is usually best demanding properties. Why that?
metengr (Materials)
12 Apr 12 21:19
Because for GTA welding, the electrode is not consumed as part of the weld deposit. This means filler metal is added separately and can be manipulated by the welder. The solid wire can be matched to the base metal composition with no supplemental additives, as is with other welding processes that use flux.
Second point is that GTA welds are shielded by gas versus slag (molten flux). This eliminates potential inclusions and slag pockets resulting in high quality GTA weld deposits.
http://www.twi.co.uk/services/technical-information/job-knowledge/job-knowledge-6-tungsten-inert-gas-tig-or-gta-welding/
bhollands (Materials)
13 Apr 12 8:35
GTAW or TIG uses a small, sharp, non-consumable electrode and a shielding gas that keeps the arc very tight. This allows for less heat input into the weld and a smaller heat affected zone (HAZ). With the tighter arc you get good penetration into the base metal.
A GMAW arc in spray transfer will give you good penetration and uses basicly the same filler metal but has a larger arc, a larger heat input and a larger HAZ.
Bob
stanweld (Materials)
13 Apr 12 9:22
bholland,
I'm looking at a narrow groove, automatic orbital, GTAW deposited weld cross section and I can assure you that the HAZ is not smaller than similar weld deposits made with GMAW spray arc that I have examined. HAZ size is also be affected by the total heat input - travel speed being a primary variable and travel speed with GTAW, especially manual GTAW, is quite slow compared to other processes.
brimstoner (Materials)
17 Apr 12 23:07
One aspect often ignored is energy efficiency of a process, and GTAW can be extremely low.  This has a lot to do with the filler metal being independent of the arc.  The HAZ is not necessarily smaller just because the weld bead is.
Distortion (shrinkage, angular) also increases with manual GTAW.
Close Box
Join Eng-Tips® Today!
Join Us             Close
