Plate Splices
Plate Splices
We are fabricating to D1.1 but this may also fall under AISC as well.
I have not found in either where there is a specification stating that plate splices must be staggered. In other words, you must avoid forming a "cross-hair" with splices.
Can anyone substantiate my findings, or lack thereof, in D1.1 and AISC?
The GM and other "old schoolers" insist that there must be a 5X thickness worth of stagger for seams. It creates a little more difficulty in rolling when this is done also.
RE: Plate Splices
Best regards - Al
RE: Plate Splices
Someone has come up with a 5X the thickness rule so that you end up with 2 "T" intersections instead of a "cross" intersection.
