Cutting a Groove in a cylinder
Hello all.
I need to cut out this section, and I think I need to use revolve cut. Here is a picture. Can someone tell me how to cut out this section along the interior of this wall?
RE: Cutting a Groove in a cylinder
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
2.create sketch of profile on new plane.
3.Cut-revolve your sketch, using your existing axis.
I would cut the circular channel in first by revolving the cut profile, then add the slots. Easier than how you have it laid out and probably the way the machinist would do it.
Cockroach
