Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just a quick note to say, "THANKS!" for these forums...The site is very well layed out and easy to use. Thanks for bringing us together - we need each other."
Geography
seymours2571 (Mechanical)
12 Apr 12 12:24
Hello Everyone,
This is a just a general question to the experts out there.  In my experience running simulations using bonded contact with the penalty method in Ansys Workbench I have a lot of difficulty obtaining convergence if the forces at the bonded connection are tangential as opposed to normal to the bonded surfaces.  I try a variety of methods to help with convergence including pinball adjustments and normal stiffness factor adjustments, but none seem to help.  My best option typically is to change the formulation to MPC instead of penalty.
I have read quite a bit of documentation, but still cannot find a good explanation as to the cause of this.  I assume that the bonded connections have tangential stiffness, but I am not sure if it is controlled by the normal stiffness factor or if there is a separate command that needs to be issued for tangential stiffness.
Any insight would be much appreciated.
steve
Stephen Seymour, PE
Seymour Engineering & Consulting Group
www.seymourecg.com
Close Box
Join Eng-Tips® Today!
Join Us             Close
